Page 3 of 3
Re: Hello all new here
Posted: Thu Sep 09, 2021 11:51 am
by SikSyco
This was the rust I was dealing with on the 231 so it currently being installed into a silver 192 shell
Posted: Thu Sep 09, 2021 4:17 pm
by ChrisHolmes
Crumbs!
Posted: Fri Sep 10, 2021 6:21 am
by SikSyco
More rot
Posted: Fri Sep 10, 2021 6:23 am
by SikSyco
Looking better now though, hopefully be ready before japfest
Posted: Thu Sep 16, 2021 7:16 am
by SikSyco
More going on!
Posted: Tue Sep 28, 2021 10:07 am
by SikSyco
Morning all after the engine swap into another chasis we can't work out if there's supposed to be a vacuum tube from the green and white one way check valve to anywhere on the car, green side is connected under the throttle body can't figure out the white side connection.
Posted: Tue Sep 28, 2021 3:04 pm
by Ollie
Yes there should be. The unconnected side attaches to the VFAD under the air box. If you go here
viewtopic.php?f=58&t=35629
Open the documents, in engine, intake air system hose routing. You'll see where it goes.
Posted: Sat Oct 02, 2021 7:41 pm
by SikSyco
So one more thing got the car back but after the change of shell my abs and traction control lights are constantly on checked with torque and it says there both a CANBUS issue does anyone know of where the sensors are or if there is an easily missed one?
Posted: Sat Oct 02, 2021 7:55 pm
by Shagrington
3rd brake light? My bulb failed and that happened to mine a while back. I'd read about it on here so I was pretty sure that was my issue when it happened, hopefully yours is as easy to find what it is.
Posted: Sat Oct 02, 2021 8:02 pm
by SikSyco
Shagrington wrote: ↑Sat Oct 02, 2021 7:55 pm
Fingers crossed I'll order some for Monday, thanks
Posted: Sat Oct 02, 2021 8:30 pm
by 30405
SikSyco wrote:Shagrington wrote: ↑Sat Oct 02, 2021 7:55 pm
Could be split wiring between the boot lid and 3rd brake light as well.
Posted: Sun Oct 03, 2021 9:38 am
by SikSyco
Vj4sothername wrote: ↑Sat Oct 02, 2021 8:30 pm
Awesome thanks, will check it over aswell. Will. Also some some pics of the non rotted shell up at some point turned our quite well just need to sort some surface rust.
Posted: Sun Oct 10, 2021 11:06 am
by SikSyco
Woohoo it's finished its transformation for this this year and it's back in the road until it gets garaged for the winter...
Posted: Sun Oct 10, 2021 11:08 am
by SikSyco
Anyone else with and enlarged/ large street port feel like a turbo kicks in at 7k? I don't know if its because of the street port or because of something else.
Posted: Wed Jun 22, 2022 9:26 am
by SikSyco
Car is doing well, couple more odds and sods then it's time to be thinking about finally fitting a turbo
Posted: Sun Jul 31, 2022 9:37 pm
by SikSyco
Quick question are the diffs on the 192 and 231 interchangeable? Mine is making noises at all revs in all gears.
Posted: Mon Aug 01, 2022 1:27 am
by Shagrington
As far as I know they are the same (and hopefully someone who actually knows what they're talking about will confirm that or prove I'm an idiot).
Posted: Mon Aug 01, 2022 7:30 am
by DrewR3
SikSyco wrote: ↑Sun Jul 31, 2022 9:37 pm
Pop the question in the Spin Doctors section, they are more likely to look and answer in there. I imagine they know straightbaway for a quick answer, i believe they are all interchangeable including the R3? Better to confirm with those who know for definate though. Also try the quick search option on forum, someone may have asked this before?
Posted: Mon Aug 01, 2022 2:05 pm
by Lemon
192 and 231 diffs are the same, the only difference are in some of the gearbox ratios (i believe 4th and 5th are essentially the same between the 192 and 231).
the R3 does have a different final drive though.
