Hello all new here
- Colour: Aluminium Silver
- Has thanked: 14 times
Re: Hello all new here
This was the rust I was dealing with on the 231 so it currently being installed into a silver 192 shell
Martin
Crumbs!
More rot
Martin
Looking better now though, hopefully be ready before japfest
Martin
More going on!
Martin
Morning all after the engine swap into another chasis we can't work out if there's supposed to be a vacuum tube from the green and white one way check valve to anywhere on the car, green side is connected under the throttle body can't figure out the white side connection.
Martin
- Been thanked: 283 times
Yes there should be. The unconnected side attaches to the VFAD under the air box. If you go here viewtopic.php?f=58&t=35629
Open the documents, in engine, intake air system hose routing. You'll see where it goes.
- SikSyco (Sat Oct 02, 2021 7:38 pm)
So one more thing got the car back but after the change of shell my abs and traction control lights are constantly on checked with torque and it says there both a CANBUS issue does anyone know of where the sensors are or if there is an easily missed one?
Martin
3rd brake light? My bulb failed and that happened to mine a while back. I'd read about it on here so I was pretty sure that was my issue when it happened, hopefully yours is as easy to find what it is.
- SikSyco (Sat Oct 02, 2021 8:01 pm)
Fingers crossed I'll order some for Monday, thanksShagrington wrote: ↑Sat Oct 02, 2021 7:55 pm3rd brake light? My bulb failed and that happened to mine a while back. I'd read about it on here so I was pretty sure that was my issue when it happened, hopefully yours is as easy to find what it is.
Martin
- Has thanked: 750 times
- Been thanked: 175 times
Could be split wiring between the boot lid and 3rd brake light as well.SikSyco wrote:Fingers crossed I'll order some for Monday, thanksShagrington wrote: ↑Sat Oct 02, 2021 7:55 pm3rd brake light? My bulb failed and that happened to mine a while back. I'd read about it on here so I was pretty sure that was my issue when it happened, hopefully yours is as easy to find what it is.
- SikSyco (Sun Oct 03, 2021 9:37 am)
Awesome thanks, will check it over aswell. Will. Also some some pics of the non rotted shell up at some point turned our quite well just need to sort some surface rust.Vj4sothername wrote: ↑Sat Oct 02, 2021 8:30 pmCould be split wiring between the boot lid and 3rd brake light as well.SikSyco wrote:Fingers crossed I'll order some for Monday, thanksShagrington wrote: ↑Sat Oct 02, 2021 7:55 pm3rd brake light? My bulb failed and that happened to mine a while back. I'd read about it on here so I was pretty sure that was my issue when it happened, hopefully yours is as easy to find what it is.
Martin
Woohoo it's finished its transformation for this this year and it's back in the road until it gets garaged for the winter...
Martin
Anyone else with and enlarged/ large street port feel like a turbo kicks in at 7k? I don't know if its because of the street port or because of something else.
Martin
Car is doing well, couple more odds and sods then it's time to be thinking about finally fitting a turbo
Martin
Quick question are the diffs on the 192 and 231 interchangeable? Mine is making noises at all revs in all gears.
Martin
As far as I know they are the same (and hopefully someone who actually knows what they're talking about will confirm that or prove I'm an idiot).
- SikSyco (Mon Aug 01, 2022 7:21 am)
- Club Chairman
- Has thanked: 52 times
- Been thanked: 298 times
Pop the question in the Spin Doctors section, they are more likely to look and answer in there. I imagine they know straightbaway for a quick answer, i believe they are all interchangeable including the R3? Better to confirm with those who know for definate though. Also try the quick search option on forum, someone may have asked this before?
- Been thanked: 59 times
192 and 231 diffs are the same, the only difference are in some of the gearbox ratios (i believe 4th and 5th are essentially the same between the 192 and 231).
the R3 does have a different final drive though.
- These users thanked the author Lemon for the post (total 2):
- warpc0il (Mon Aug 01, 2022 2:28 pm) • SikSyco (Mon Aug 01, 2022 7:24 pm)
Thanks, Stu
Mad as anything
Mad as anything
